(#151)
Get A Gun Get A Gun is offline
Car: F30 n55
Default 05-02-2013, 08:55 PM
Originally Posted by Eric SS
Do they have an Alpina flash for the F30? One of my biggest gripes on my new car is the lack of being able to see what gear I'm in in D. Coming for a DCT 335is I got used to being able to always see my gear.
So can this be done to the f30s. Will it benefit the the performance.
Also what cables and software do you need to do this.
cartmanr6's Avatar
cartmanr6 cartmanr6 is offline
Car: 335i E90 LCI
Default 05-21-2013, 04:30 AM
I got a problem there.
My Car: E90 335i LCI N54 from 12/2009.
Just before flashing i get an error (see attached files).
I used SPDaten v49.3.
Everything else works just fine (INPA, Tool32, NCS Expert...)
Coding is still working.
WinKFP Setup seems fine -> I can go through the DIY without a Problem.
After pressing the button for flashing i get the Message "You can Flash 62 more times...".
To that point everything is fine.
3 sec later i get that error.
"SECURITY ACCESS DENIED" <- Sounds a bit weird.
"ECU CONDITIONS NOT CORRECT" <- ?!
I'm wondering because like i said everything else works just fine...
I can also flash other ECU's.
Only my TCU won't work...
Luckily my Gearbox is still working
Settings are fine, has to be another problem...
Someone got an idea?
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default clearing - 05-21-2013, 06:01 AM
Originally Posted by teknic90
Good call . Going to do this first thing tomorrow! Here's the reset for everyone's benefit
1) foot off accelerator, hit ignition on
2) hold accelerator down for 30 seconds
3) WHILE HOLDING ACCELERATOR hit ignition button again to turn the car off
4) once off, remove foot from accelerator.
is it cool to do this after the flash is in?
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 05-21-2013, 06:28 AM
VIN entered correctly? Or try unchecking UIF write in configuration. Since I have a JB4, whenever I code/flash I have to be in map 0.
harry$ harry$ is offline
Default 05-21-2013, 07:53 AM
What version of bmw standard tools are you using?
halcyon026 halcyon026 is offline
Car: 08 335XI
Default 05-29-2013, 09:16 AM
Anyone in Boise, ID that does this flash??
v1ru3 v1ru3 is offline
Car: 07 335i
Default 05-29-2013, 03:52 PM
I did it yesterday, runs pretty good.
Did you get a chance to do it?
Originally Posted by 335iTT
Hmm- 05/07 production-- check!
Looks like I can benefit from this flash-- anyone around Atlanta area that has tried it successfully?
J
Hellraiserharris's Avatar
Hellraiserharris Hellraiserharris is offline
Car: 14' 435i
Default 05-29-2013, 05:29 PM
Anybody in the South Carolina are that can do this coding?
14' 435i. M-Sport, JB4 Stage 2, BMS Intake, more to come
Car: 2007 335i E92
Default 05-30-2013, 05:27 AM
I can do it if you come here to Charleston.
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 05-30-2013, 08:44 AM
Did you ever get this problem resolved? My cars production was 09/2009 which means I'd probably have the same trouble you are.
Default 05-30-2013, 01:06 PM
^ I did an 09 e90 with paddle shifters. Although I'm unsure of exact build date, I had no such issues. You could pm AZ335IAT and confirm the build date as it was his car.
Click on the banner to visit our online store.
Car: 14' 435i
Default 05-30-2013, 01:40 PM
your suppose to use the part 2 flash if your paddles don't work.
(Alpina B3 Flash Part II: DIY for not working paddles Shifters after flash)
http://www.bimmerboost.com/showthrea...rs-after-flash
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 05-30-2013, 02:49 PM
Build date should have been around 02 or 03-2009 as warranty was up in early May.
myst3k myst3k is offline
Car: 2010 535i xDrive
Default 05-30-2013, 04:16 PM
I just tried this on my 2010 535i xDrive M-sport build date 05/09. It bricked the tranny for a bit till I flashed back GKE215 to ZB 7601460. I initially went to ZB 7601458 which supposedly enables sport mode, but it made my car feel sluggish. ~May~ have needed to do the tranny adaptation reset, but happy its back to normal pulls on JB4 G4 map 5 with E85.
Hopefully this post may save someone else from bringing it back to the deal if they try this with no success.
Car: 14' 435i
Default 05-30-2013, 05:27 PM
send me a pm and give me a price and how to contact you when I can get there. thanks
Caruso0644's Avatar
Caruso0644 Caruso0644 is offline
Default 05-30-2013, 07:41 PM
Can anyone perform this flash for me up in the Albany, NY area? I'll even take a couple hour drive...
15' M4 / 08' E92 335i : Montego Blue : JB4-G5 : DCI : BMSMeth : BMSoilCC : VRSF DP's : VRSF Front Mount : 19" Vertini Magic : Bridgestone RE-11 : Carbon CSL Trunk Lip : MtechRearBumper : Mtech FrontBumper <----------- FOR SALE! $22k PM ME
Default 05-30-2013, 07:45 PM
That's because this is a B3 flash....not B5...it is not compatible with your car. Nice job noting the original flash and getting it back to stock though!
Car: 07 335i
Default errors stored after ALPINA B3 trans flash - 05-31-2013, 04:52 PM
Any of you guys seen anything like this after the flash? I scanned for errors using INPA and this is what i get.
I cleared the errors and try to rescan next week again. Car runs good and no check light engine.
Default 05-31-2013, 04:58 PM
What's the error and are you talking under "engine" or "transmission". Under transmission there is a 510 or 520 error...don't recall which off the top of my head, that comes up and is fine...everybody gets it although last time I checked...I didn't have it but have done some additional coding for a paddles retrofit...either way it's okay. If it's something else...post it up.
Edit...I see you posted an image...but I can't read it. Maybe it's just me
Car: 07 335i
Default 05-31-2013, 06:00 PM
You're right the attachments I've made are useless... these are the errors i got:
If i look under details i see most of these popped up around the date i did the flash (i looked at the mileage)...
Hope it's not an integration issue with the other modules i have...
Oh and, It's a 335i built 04/2007, no paddles.
E R R O R M E M O R Y
Date: 31.05.2013 19:36:15
Model: E89X
Scope: all control module
JobStatus: OKAY
Quantity: 23
ADR Gen. name JobStatus
92 VIRTSG92 ERROR_ECU_SERVICE_NOT_SUPPORTED
ADR Gen. name JobStatus Number of errors
Error code Kind of error
00 JBBF OKAY No Error stored
01 MRS OKAY No Error stored
12 DME/DDE OKAY 15 Error stored
CD99 84
CDAD 04
CDA1 04
CDA8 84
CD98 04
CD9C 04
CDA5 04
CD95 04
CDA0 04
2DC3 04
CD94 84
2F4C 04
CDA9 04
CDA6 04
CD9F 04
17 EKP OKAY No Error stored
18 EGS OKAY 1 Error stored
511B 61
20 RDC OKAY No Error stored
27 PGS OKAY No Error stored
29 DSC OKAY 1 Error stored
D357 24
36 TEL/MULF OKAY No Error stored
37 AMP OKAY No Error stored
40 CAS OKAY 3 Error stored
A0B1 28
A0B5 24
A118 21
53 IBOC OKAY No Error stored
54 RADIO OKAY No Error stored
55 ISPB OKAY No Error stored
56 FZD OKAY No Error stored
60 KOMBI OKAY 2 Error stored
A3AA 20
E104 20
62 MOSTGW OKAY No Error stored
63 MASK/CCC OKAY No Error stored
64 PDC OKAY No Error stored
6D FAS OKAY No Error stored
72 FRM OKAY No Error stored
78 KLIMA OKAY No Error stored
Default 05-31-2013, 06:20 PM
I know that is close to the deadline but don't recall the cutoff. Do you get D1, S1, M1 indications showing the gear you're in?
Car: 07 335i
Default 05-31-2013, 06:45 PM
the cutoff is 03/07, the flash was successful no issues there and yes, i get d1-d6 also s1-s6
i guess the only real error is this one:
Date: 31.05.2013 21:06:57
ECU: GS19D
JobStatus: OKAY
Variant: GS19D
RESULT: 1 error in error memory !
511B Coding error
Error counter: 1
Logistic counter: 40
Mileage 100200 km
Battery Voltage 0.00 Volt
Output Speed 0.00 rpm
average wheel speed powered wheels 0.00 km/h
status ignition undefined 0-n
Coding was defective
Test conditions fulfilled
Error present now and already stored
Error would not cause a warning lamp to light up
Error code: 51 1B 61 00 00 00 00 01 28 30 ED 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00
Default 05-31-2013, 08:02 PM
Nope...that looks good...you're rockin the flash and that is the error code I was speaking of...everybody gets it. Don't sweat it.
Car: 07 335i
Default 06-01-2013, 05:17 AM
thanks , I figured is not a huge issue.
Car: 07 335i
Default 06-02-2013, 03:03 PM
has anybody tried to correct this error with NCSExpert by doing this:
EGS_CSUM_MONITOR - CHECKSUM MONITORING FOR ELECTRONIC TRANSMISSION CONTROL (EGS)
nicht_activ
did it work?
Copyright 2007 - 2015, N54tech.com
